Does 2811 support CCME and Crypto IPSEC on the same IOS
Mar 22nd, 2010
HI Guys,
I was just about to order a 2811 ISR router, i want to run it as a CCME and also establish a Crypto Ipsec Vpn to a another site using ASA.
is this possible with some spservice or advservice IOS
thanks in advance
Juan Carlos Ari... Mon, 03/22/2010 - 11:59
Hi there,
Yes, it's possible, I have the same situation running for almost a year without any problem.
Hope this helps.
alanhong Mon, 03/22/2010 - 12:17
Thanks for the lightening Reply,can you share the IOS version(name) so i dodnot have to waste time trying out
