2811 used as VPN gateway and SIP-PRI gateway
Mar 22nd, 2010
Does anyone have any reasons why a 2811 should _not_ be used as both a low traffic (5-15 concurrent calls max) SIP/PRI gateway and a VPN gateway (for about 10 VPNs, up to 5mbps traffic total) at the same time?
768megs of ram, adv ip services 12.4(22)T
Federico Coto F... Fri, 04/02/2010 - 16:01
  • Green, 3000 points or more
As trippi say, not at all.
Having an Adv. IP Services IOS and being a 2811, there's no reason why it could not handle the traffic (encryption and voice, besides regular routing).
As you might know, all scenarios are different and there could be possible reasons to do one thing or the other, but this router can definitively be used simultaneously to both functions.
Hope it helps.
Federico.
