CCX 5 Cluster error Datastore: Repository
I have "CCX 5.0(2)_Build064 Premium" on  a cluster CCXPRI and CCXSEC.
On System->Datastore Control Center->Repository it shows only CCXPRI registered. And get the following failure:
"failure ocurred while performing the operation. The cluster information and subscriber configuration does not match. The subscriber might be dropped (Please check SQL server log for more details).
How can I fix this failure?
David Hailey Mon, 03/22/2010 - 15:17
  • Purple, 4500 points or more
If you grab the SQL log as the error indicates and post the info, that would be greatly appreciated.  Could be a few different things.
Hailey
Please rate helpful posts!
Aaron Harrison Tue, 03/23/2010 - 01:53
  • Community Spotlight Award,
    Member's Choice, May 2015
A quick way to fix this (if it is the Subscriber that has the problem obviously... probably not wise on a Publisher) is to go into Component Activation, and deactivate the Repository data store.
Once done, reactivate it. This rebuilds the SQL replication.
If it fails for whatever reason, report back the exact error as you must have something fundamental wrong that is preventing replication from setting up (e.g. name resolution - have you added the servers to each servers' host file?)
Aaron
Please rate helpful posts...
Hi.
I just restored  the CRS SQL Server–Repository from System->Control Center->CCXSEC.
But the error "failure ocurred while performing the operation. The cluster information and subscriber configuration does not match. The subscriber might be dropped (Please check SQL server log for more details)”  Still Continue  appearing in the Datastore Control Center->Repository.
The tracing and file generated is:
[3/25/2010 7:46:18 PM]MXMXC-CCE-PRI\CRSSQL.db_cra: {call sp_MSgetversion }
Connecting to Subscriber 'MXMXC-CCE-SEC\CRSSQL.db_cra'
Server: MXMXC-CCE-SEC\CRSSQL
DBMS: Microsoft SQL Server
Version: 08.00.2156
user name: dbo
API conformance: 2
SQL conformance: 1
transaction capable: 2
read only: N
identifier quote char: "
non_nullable_columns: 1
owner usage: 31
max table name len: 128
max column name len: 128
need long data len: Y
max columns in table: 1024
max columns in index: 16
max char literal len: 524288
max statement len: 524288
max row size: 524288
[3/25/2010 7:46:18 PM]MXMXC-CCE-SEC\CRSSQL.db_cra: {call sp_MSgetversion }
Connecting to Publisher 'MXMXC-CCE-PRI\CRSSQL.db_cra'
Server: MXMXC-CCE-PRI\CRSSQL
Version: 08.00.2156
user name: dbo
API conformance: 2
SQL conformance: 1
read only: N
owner usage: 31
Version: 08.00.2156
user name: dbo
API conformance: 2
SQL conformance: 1
read only: N
owner usage: 31
Version: 08.00.2156
user name: dbo
API conformance: 2
SQL conformance: 1
read only: N
owner usage: 31
Version: 08.00.2156
user name: dbo
API conformance: 2
SQL conformance: 1
read only: N
owner usage: 31
Version: 08.00.2156
user name: dbo
API conformance: 2
SQL conformance: 1
read only: N
owner usage: 31
Version: 08.00.2156
user name: dbo
API conformance: 2
SQL conformance: 1
read only: N
owner usage: 31
Percent Complete: 4
Downloaded 12 data changes (11 inserts, 0 updates, 1 deletes, 0 conflicts).
Percent Complete: 4
Uploading data changes to the Publisher
Percent Complete: 4
No data needed to be merged.
Percent Complete: 4
Downloading data changes to the Subscriber
Percent Complete: 4
Percent Complete: 4
Percent Complete: 4
Percent Complete: 4
Percent Complete: 4
Percent Complete: 4
Percent Complete: 4
Percent Complete: 4
Percent Complete: 4
Downloaded 1 data changes (1 inserts, 0 updates, 0 deletes, 0 conflicts).
Percent Complete: 4
Percent Complete: 4
Percent Complete: 4
Percent Complete: 4
Percent Complete: 4
Percent Complete: 4
Percent Complete: 4
Percent Complete: 4
Percent Complete: 4
Percent Complete: 4
Percent Complete: 4
Percent Complete: 4
Percent Complete: 4
Aaron Harrison Tue, 03/30/2010 - 02:02
What exactly do you mean by ' I just restored the CRS SQL Server–Repository from System->Control Center->CCXSEC.'?
Aaron
