H-REAP vlan template?
Mar 22nd, 2010
Is there a way to set-up the locally switched H-REAP vlan(s) via WCS template?
Scott Fella Fri, 03/26/2010 - 05:28
I know in WCS v6.0.181.0 you can set the native vlan and the ssid to vlan mappings.  What version are you running?
mscherting Fri, 03/26/2010 - 09:21
I'm currently running WCS
I've been looking for a template to set the H-REAP vlan mappings, rather than doing it per AP.  Either I'm not finding it or doesn't support it.
May be time to upgrade.
Scott Fella Fri, 03/26/2010 - 09:28
You create a template and have to apply it to an AP oR multiple AP's
mscherting Fri, 03/26/2010 - 09:42
On the AP parameters tab, in the LW AP template detail I can enable H-REAP and select a native vlan but the Profile Name - VLAN mappings area doesn't take input or offer a option to set or select local vlan IDs.
I'll dig up the release notes on the newer version of WCS.
sschmidt Fri, 03/26/2010 - 09:44
Did you click the "Show All Profile-Mapping"?  Or is this still not what you are looking for?
mscherting Fri, 03/26/2010 - 09:55
When I click that, nothing gets populated.  I've already got half a dozen H-REAP sites with different native and local vlans.  I'm just looking for a way to do groups of APs, rather than one at a time.
I'll refresh the configs again.
mscherting Fri, 03/26/2010 - 11:01
Nope, even after refreshing configs from controllers, retaining template associations.
Scott Fella Fri, 03/26/2010 - 12:55
Here is what I see on my lab WCS... I check H-REAP/REAP Configuration, then click on Show All Profile-Mapping.
mscherting Sun, 03/28/2010 - 08:05
Thanks for the screen shots.  I took off early Friday.
My screen shots would look like your first one.  Unlike your second one, I never see anything in the Profiles box.
Perhaps I'm shooting myself in the foot using the same SSID at the H-REAP sites as at the centrally switched sites.  The difference being the H-REAP WLANs are mapped to the management interface but with traffic dumped onto a locally routed/switched vlan.  Strange though, not one SSID shows up in the profiles box.
I would expect to see multiples of the same SSID with differing locally switched vlan numbers corresponding to local vlans at the different H-REAP sites.
Scott Fella Sun, 03/28/2010 - 08:36
That would not matter... my ssid's are also set on AP's that are centrally switched so I don't know why your mappings don't show up.
ibrommer_fastenal Thu, 10/07/2010 - 12:33
Go to:
Configure >  Controller Template Launch Pad >  WLANs >  WLAN Configuration
Select a WLAN that you want to show up in the profiles box.
Go to the Advanced Tab and check the box next to H-REAP Local Switching.
The WLAN will now show up in the profiles box in the AP Template.
Trending Topics - Security & Network
