VSS with dual supervisor in each chassis
Mar 22nd, 2010
VSS doesn't support dual SUP in each chassis right now. What happen if I install dual SUP in each VSS chassis?
Does anyone know the roadmap when and which new IOS can support?
Best Regards,
Giuseppe Larosa Tue, 03/23/2010 - 03:41
Hello Jackson,
that you are going to look for troubles.
best case:
second supervisor is held down
worst case:
it causes problems
the feature can be in the road-map no more detailed info up to know
Hope to help
gnijs Wed, 03/24/2010 - 02:27
Support for dual supervisors and VSS is on the roadmap for the next software release, expected H2Y2010 hopefully...
