ip address
Mar 22nd, 2010
hi!
i've a media streaming server that require 6 multicast address in our LAN. What would be the range of multicast ip address to be used in this case? The routers are turned on with ip multicast enabled command. what's the most suitable range of ip to be used? thanks.
Ganesh Hariharan Tue, 03/23/2010 - 00:13
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
hi!
Multicas range as reserved by IANA is 224.0.0.0 through 239.255.255.255, Genrally for using mulitcast ip address make use from 239.0.0.1 onwards and for more details on multicast ip addres and well known reserved address in mulitcast range check out the below link.
http://www.iana.org/assignments/multicast-addresses/
Hope to Help !!
Remember to rate the helpful post
Ganesh.H
dkblee@hotmail.com Tue, 03/23/2010 - 01:07
hi! what's the normal mask used for this case...is it /16? if i would to use eg. 239.255.80.1-6/16. do i need to configure a route in my ospf configuration just like my normal netowrk?
thanks.
Jon Marshall Tue, 03/23/2010 - 10:16
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
dkblee@hotmail.com
thanks.
Multicast addresses do not use subnet masks in the same way unicast addresses do. Think of multicast addresses less as an IP address and more as a group identifier.
You shouldn't need to configure specific routes because once you enable ip multicast routing then the multicast routing protocol, usually PIM, will exchange multicast routes between the routers.
Cisco is currently donating money to the Haiti earthquake appeal for every rating so please consider rating all helpful posts.
Jon
Ganesh Hariharan Tue, 03/23/2010 - 21:33
thanks.
As Jon said Muliticast ip don not require any mask these ip will be cofnigured in you muliticast server and client and unicast ip address of the server should be reachble to all clients in your network.Mulitcast routing will take care for reachablity via using via PIM sparse or dense mode.
Check out the below link for multicast routing configuration  in router.
http://www.cisco.com/en/US/docs/ios/12_2/ip/configuration/guide/1cfmulti.html
Hope to Help !!
Ganesh.H
