TACACS+ Authentication For Cisco NAM
Mar 22nd, 2010
Hi All,
I have an cisco ACS v5.1 and also a cisco NAM. Currently, I have configured TACACS+ on the NAM and the ACS v5.1 however when I try to access the NAM, the ACS v5.1 has an error message of "TACACS+ authentication ended with error" and I am not able to access the equipment.
For your information, I have no problem with others equipment TACACS+ authentication with the same ACS.
Please advise.
Thks and Rgds
Richard Burts Sun, 03/28/2010 - 15:26
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Steven
I would first suggest that you verify that your ACS has an appropriate and correct entry configured for the NAM as a client. Assuming that is correct then I would suggest that you check and verify that the NAM is originating its TACACS requests from the address that you configured for the client on the ACS and that the shared secret is the same on both devices.
If those are correct then I would suggest to look in the Failed Attempts report of ACS and see if it provides a better identification of the problem.
Rick
