Host Scan - Checking Processes for MacOS
Mar 22nd, 2010
I have a Cisco ASA 5520 based SSL VPN implementation and for my client less access, i have configured the storage.exe (in windows) process should run in order to continue with the connection (ensuring that the CSD is working fine).
how can i do the same under Mac OS? is there a way?
thanks!!
ksirupa Tue, 03/23/2010 - 00:26
If you have "Activity Monitor" installed on your Mac OS X, you can easily find the process name and use it very similar to the storage.exe. See the attached screenshots.
Kiran
Related Content
