03-23-2010 12:56 AM - edited 03-11-2019 10:24 AM
Hello Friends,
I am lookig to configure site-site vpn between two ADSL routers , but the problem is their public keeps changing after very re-conect from their respective
ISP. I heard there is still some solution to overcome this with the helo Dyanamic DNS registration .
Request you valubale thoughts and suggestion and apprecaite your quick resposne.
KA.
03-23-2010 01:58 AM
By, "their public keeps changing", I assume you mean public IPs?
Here is an example as to how DDNS is configured on a router using DynDNS as the DNS service (http://www.dyndns.com/).
I haven't tried this but in theory all you then need to do in the set peer command of the crypto map is to enter the DynDNS name of the remote router.
03-23-2010 03:02 AM
Hello Sean,
Yes i mean Public IP's at ADSL line will keep changing at every re-connect.
Let me try follow your instructions and see how much i will be able to solve it.
KA.
12-21-2010 07:34 AM
Hello erveryone,
i have the same project Site to Site VPN with ADSL. DynDNS works fine, but the ipsec VPN Site to Site doesnt works.
I mean, configure vpn with dynamic crypto maps should be the correct way, if I implemtation the fqdn???
If I use it with static crypto maps and static ip, it works finely.
Who has an howto to configure it?
Thanks and Best Regards
Torsten
12-22-2010 01:23 AM
then you need to use these : crypto isakmp identity hostname and crypto isakmp key xxxx hostname commands
Regards.
Alain.
