03-23-2010 01:13 AM
Hi All ,
I want to find out if I can use a cisco GLC-SX-MM SPF on an OM3 fibre.
Keith
03-23-2010 06:39 AM
Yes, you can use the GLC-SX-MM with OM-3 fiber.
The specs for OM-3 fiber is for laser-optimized 50 µm fiber with a minimum of 2000 MHz-km effective modal bandwidth (laser band-
width). Per Table 1 of the Cisco SFP specification sheet (URL below), this module pn OM-3 fiber will have an effective reach of 1000 meters.
Hope this helps!
03-23-2010 02:28 PM
Yes you can. Make sure not only both sides are using OM3 but the horizontal cabling is too. We're using OM3 all over the place.
03-25-2010 04:18 AM
Thanks a lot guys. I managed to do some tests and it seems to be working 100%
