VRF-lite on Cat3750
Answered Question
Mar 23rd, 2010
I'm tring to configure a Cat3750 Stack in 12.2(53)SE with 2 vrf but the usual ip vrf vrf-name command does not exist.
Has it been moved or removed ?
Stéph
Correct Answer by Giuseppe Larosa about 7 years 3 months ago
Hello Stephane,
>> To use multi-VRF CE, you must have the IP  services  image installed on your switch.
you have ip base so it is not supported. cisco has probably changed the mapping of features to feature set over time from 12.2(35) to 12.2(53)
Sorry to give you this bad news.
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Giuseppe Larosa Tue, 03/23/2010 - 02:40
  • Hall of Fame,
    Founding Member
Hello Stephane,
you need the appropriate IOS image and the appropriate SDM template
see
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_52_se/configuration/guide/swiprout.html#wp1319320
and for SDM template configuration
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_52_se/configuration/guide/swsdm.html#wp1198298
if you need to change the SDM template you need to reload the box for the change to take effect.
See the notes about stacks
Hope to help
Giuseppe
Stephane ARDHUIN Tue, 03/23/2010 - 04:00
Thanks for your answer,
But I still can't understand what's happening.
I have 1 opperationnal c3750 stack running in 12.2(35)SE5 ipbasek9, sdm template desktop default with 2 VRFs configured :
switch1(config)#ip vrf ?
  WORD  VPN Routing/Forwarding instance name
And now I want to do the same with a new stack running in 12.2(53)SE ipbasek9 with the same sdm template :
switch2(config)#ip vrf ?
% Unrecognized command
Any idea ?
Correct Answer
Giuseppe Larosa Tue, 03/23/2010 - 04:05
  • Hall of Fame,
    Founding Member
Hello Stephane,
Hope to help
Giuseppe
Stephane ARDHUIN Wed, 03/24/2010 - 06:14
The answer is already inside the IOS 12.2(35) :
switch1(config)#ip vrf test
% VRF-Lite is not supported in the IP Base feature set and will be removed in future releases, please refer to www.cisco.com for the feature sets that support this feature
Related Content
