Problem to display logging
Hello to all,
if i perform a "show logging" i can get this:
cme#show log
Syslog logging: enabled (11 messages dropped, 3 messages rate-limited,
                0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
    Console logging: level debugging, 23510 messages logged, xml disabled,
                     filtering disabled
    Monitor logging: level debugging, 5081 messages logged, xml disabled,
                     filtering disabled
        Logging to: vty514(208)
    Buffer logging:  level debugging, 19 messages logged, xml disabled,
                     filtering disabled
    Logging Exception size (4096 bytes)
    Count and timestamp logging messages: disabled
No active filter modules.
    Trap logging: level notifications, 11649 message lines logged
        Logging to 10.0.0.204  (udp port 514,  audit disabled,
              authentication disabled, encryption disabled, link up),
              11649 message lines logged,
              0 message lines rate-limited,
              0 message lines dropped-by-MD,
              xml disabled, sequence number disabled
              filtering disabled
Log Buffer (4096 bytes):
i need to see the 5081 messages that are logged in "Monitor logging" what is the correct way in order to display this messages?
thanks and regards.
milan.kulik Tue, 03/23/2010 - 03:38
  • Red, 2250 points or more
IMHO, issuing "term monitor" will start displaying the messages on your terminal screen on-line.
But no way to display a message history.
See logging monitor at  http://www.cisco.com/en/US/docs/ios/netmgmt/command/reference/nm_09.html#wp1066253
and terminal monitor at http://www.cisco.com/en/US/docs/ios/12_2/configfun/command/reference/frf003.html#wp1019329
HTH,
Milan
