6500 1p3q4t Best Practice Queue Configuration
Mar 23rd, 2010
I have a 6500 Sup720 I looking for a best practice for configuration of 1p3q4t queues
GigabitEthernet5/1
Model: VS-S720-10G
Type: 1000BaseLH
Speed: 1000
Duplex: full
Trunk encap. type: 802.1Q,ISL
Trunk mode: on,off,desirable,nonegotiate
Channel: yes
Broadcast suppression: percentage(0-100)
Flowcontrol: rx-(off,on,desired),tx-(off,on,desired)
Membership: static
Fast Start: yes
QOS scheduling: rx-(2q4t),
tx-(1p3q4t)
QOS queueing mode: rx-(cos), tx-(cos)
CoS rewrite: yes
ToS rewrite: yes
Inline power: no
Inline power policing: no
SPAN: source/destination
UDLD yes
Link Debounce: yes
Link Debounce Time: yes
Ports-in-ASIC (Sub-port ASIC) : 1-5 (1-2,5)
Remote switch uplink: no
Dot1x: yes
Port-Security: yes
Steve
Jon Marshall Tue, 03/23/2010 - 12:17
Steve
There is no best practice as such because it all depends on your QOS requirements within your network. Obviously the priority queue is usually used for VOIP if you are using that within your LAN.
Other than that it is entirely up to you how you classify and queue the traffic on each linecard. Be aware that QOS is handled by the PFC on the 6500 so when you apply a QOS policy to an individual port on a line card that QOS policy is applied to all ports within the same port group as the individual port.
Jon
Cisco are currently donating money to the Haiti earthquake appeal for every rating so please consider rating all helpful posts.
