DFM server stops intermittently
Mar 23rd, 2010
I have LMS server 2.6 with DFM server 2.0.13 installed, I am facing a recurring problem on the same. The DFM server stops intermittently and the reason provided is "Administrator has shut down the server"
As per the log it appears to be crashing, but am unable to find why it is crashing.
I have enclosed the log files.
Following are the notification configured on the server.
email-notification :- 2 groups(approx 400 devices) sending mails to arround 10 email id in total
snmp-trap notification :- 2 groups(approx 400 devices) forwarding traps to HPOV
Vijay Sequeira
Joe Clarke Tue, 03/23/2010 - 09:10
Something is wrong with the trap receiver.  Either you're sending too many traps to DFM, or there is a malformed trap.  It looks like the former.  DFM is running out of memory.  How many traps are you sending to DFM?  How many devices is DFM managing?  How much memory is on this server?
vaibhav.gurav Wed, 03/24/2010 - 00:24
DFM is managing 1400 devices in which CiscoWorks is configured as a Trap destination , System has 4 GB of RAM,
Is there some way I can filter Traps?
Vijay Sequeira
Joe Clarke Wed, 03/24/2010 - 22:33
About how many traps are you sending to DFM?  You can't filter the traps, but you can disable the trap listener temporarily.  Just set the trap listening port to be something other than 162.  That should cause DFM to stop processing the traps, and things should stabilize.  If they do, you will have to either add more memory, or split the managed devices up onto other servers.
