GLC-T
Mar 23rd, 2010
I have two different model's of GLC-T SFP's.  One is PN 30-1410-02 the other is PN 30-1410-03.    The -02 will not work in Nexus 5020 or an ASR-1000 router that I have, but works fine in my Cisco Wireless Controller.  The -03 works fine in any device.   My problem is when ordering, you can not specify the -03  they get ordered as GLC-T and none of my suppliers can assure me that I would get the -03   What is the difference between these two?
Giuseppe Larosa Tue, 03/23/2010 - 10:45
  • Hall of Fame,
    Founding Member
I would suggest you to open a Cisco service request to raise this question to Cisco TAC
Hope to help
Giuseppe
orrobinson Tue, 05/18/2010 - 03:52
Did you ever get an answer for this from TAC?
Any idea what the differrence is between them?
Oliver
We have the same problem, some of the GLC-T SFP work, some don't work. Even worse: Some are recognized, some not. Some of the recognized work, some not.
We have similar problems with 1000Base-SX SFPs as well. It seems the Nexus is very picky when it concerns SFP :-(
Of course each of these SFP work in our Catalyst...
Greetings
Rufer
Leo Laohoo Mon, 11/01/2010 - 15:07
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Errr ... Nexus and ASR are not suppose to support GLC-T.
Sometimes you'll see it work but Cisco TAC won't support this.
j-mccarthy Wed, 02/02/2011 - 18:29
The statement above is incorrect.
I have a Nexus 5020 running 5.0(2). The first 16 ports are 1G/10G capable.
If you insert a Rev 02 GLC-T you will see "SFP Validation Failed" when you do show interface.
However, configure "speed 1000" on the interface and the error goes away and you're good to go. I have multiple Rev 02 GLC-T working in my Nexus 5020.
jeffreybunch Mon, 02/28/2011 - 10:58
j-mccarthy,
It sounds like you have direct experience with this situation. I found the same issue. I had SFP invalid when using GLC-T on my 2232PP. I changed the speed to 1000 and it showed notconnected. However, I can't get it to show connected? I have verified the server on the other side is good by connecting my laptop via crossover. Also tried using same crossover to connect the server to the GLC (knowing it wouldn't work but grasping at straws). Did you have any other steps you had to take to get link lights with a GLC-T?
Jeffrey
