Add to cluster is failed UCCX
Mar 23rd, 2010
Hello, i have a UCCX server configured as First Node, this is in a domain, when a try to add a new server  this message appears Add to cluster is failed because of ClusterException invalid AdminPwd: AdminPwd(CSERVUCCX01)=conetwor*2009, AdminPwd(CSERVUCCX02)=ciscocisco.
The other server is in a Workgroup.
Thanks for your help
Jose Luis Arango Carvajal
Tanner Ezell Tue, 03/23/2010 - 08:33
  • Silver, 250 points or more
Two things:
A. Did you just say your UCCX box was on the domain?! That's a big no-no
B. You just pasted your administrator passwords
C. Passwords don't match.
On Tue, Mar 23, 2010 at 11:29 AM, Jarango_717
Aaron Harrison Tue, 03/23/2010 - 08:33
  • Community Spotlight Award,
    Member's Choice, May 2015
When you add to the cluster, you should make sure that:
1) Your local administrator account has the same password on both boxes
2) In the Initial setup routine in appadmin, you are entering the credentials for an administrator of the UCCX application, not the Windows administrator account.
Aaron
Please rate helpful posts..
Jose Arango Tue, 03/23/2010 - 09:26
Yeah the servers have the same local account (Admin
istrator) and password,  in the initial setup i use the  credentials for an administrator of the UCCX application.
