DMA ExportDatabase Error
Mar 23rd, 2010
Hi:
     Im planning to upgrade CUCM from 4.1.3(sr6) to 7.0.2 and I ran the DMA form CUCM 4.1.3 but the Export is failed, I saw the "DMAErrors" Log and it show me this:
*          The following section displays errors found during
*          CallManager database export.
*          Date/Time  : 03-23-10/10:12:33 AM
ExportDatabase, returning [Failure, Inaccessible or Incompatible Database Version]
*          End of errors found during CallManager database export.
*          Date/Time  : 03-23-10/10:12:44 AM
    I realy dont know why tell me that the Database is Incompatible, attach the Exportdb.log. In this log shows a DATABASE=PRE_SEADRAGON but this is not the name of the Database.
Rob Huffman Tue, 03/23/2010 - 10:56
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi there,
It sure sounds like this bug;
CSCsz63731            Bug Details
DBConnection0 Database=PRE_SEADRAGON on DMA Export Fail
Symptom:
Replication failure in 4.x after DMA failed export. DBConnection0 Database value in registry under HKLM/Software/Cisco Systems. Inc/DBL is set to PRE_SEADRAGON.
Conditions:
This can occur if DMA export fails on early migration step.
Workaround:
Modify the registry key HKLM/Software/Cisco Systems Inc./DBL DBConnection0 Database= value to the correct CCM03X Database instead of PRE_SEADRAGON.
Status
Fixed
Severity
2 - severe
Last Modified
In Last Year
Product
Cisco Unified Communications Manager (CallManager)
Technology
1st Found-In
7.0(2.10000.18)
7.1(2.10000.4)
Fixed-In
7.1(2.39000.46)
6.1(3.9901.183)
6.1(4.1000.10)
7.1(3.10000.11)
Hope this helps!
Rob
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
https://supportforums.cisco.com/docs/DOC-8727
Related Content
