Gateway IOS -> SIP callerid name issue
Mar 23rd, 2010
I have a PRI into a 2800 and it is converting it to SIP and sending to our SIP Server.  Calls work fine and we can see the called number, but not the called name.  Debugs on the Cisco show the name, it is just not getting sent in the SIP invite or any subsequent messages.  Any ideas how to fix this?  We have another PRI into a different Cisco and it works fine, but it is on a different PRI provider and they send the name a little differently.  Here is teh debug message on the gateway for the one that does NOT work:
        Bearer Capability i = 0x8090A2
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98385
                Exclusive, Channel 5
        Display i = 'PEDER'
        Calling Party Number i = 0x2180, '201xxxxxxx'
                Plan:ISDN, Type:National
        Called Party Number i = 0xC1, '201yyyyyyy'
                Plan:ISDN, Type:Subscriber(local)
Mar 23 10:36:40: ISDN Se1/0:23 Q931: TX -> CALL_PROC pd = 8  callref = 0x82AD
Related Content
