DMVPN Hub-to-Hub + spokes scenario
Mar 23rd, 2010
st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
I am having issues getting HUB-to-HUB connectivity working.  As practice, I’m using the Hampton, VA hub site and the Atlanta, GA hub site.  (PLEASE DON'T CONFUSE this with Cisco dual-hub configurations)
I am able to get to work and EIGRP to route if I configure Atlanta as:
interface Tunnel1
  description (Spoke Tunnel)
  bandwidth 1500
  ip address 10.250.210.1 255.255.255.0
  no ip redirects
  ip mtu 1472
  ip nhrp authentication SPOKE
  ip nhrp map multicast dynamic
  ip nhrp network-id 10001
  ip nhrp holdtime 700
  ip nhrp max-send 65535 every 10
  ip nhrp cache non-authoritative
  ip tcp adjust-mss 1432
  no ip split-horizon eigrp 250
  load-interval 30
  delay 1000
  keepalive 10 7
  tunnel source 172.17.3.1
  tunnel mode gre multipoint
  tunnel key 10001
hold-queue 4096 in
  hold-queue 4096 out
interface Tunnel2
description (Global-Hub Tunnel)
bandwidth 1500
ip address 10.250.200.1 255.255.255.0
no ip redirects
ip mtu 1472
no ip next-hop-self eigrp 250 (is this needed?)
ip nhrp authentication GLOBAL
ip nhrp network-id 10002
load-interval 30
delay 1000
keepalive 10 7
tunnel key 10002
hold-queue 4096 in
hold-queue 4096 out
router eigrp 250
  redistribute static
network 10.250.200.0 0.0.0.255
  network 10.250.210.0 0.0.0.255
  no auto-summary
router bgp 1150
  no synchronization
  bgp log-neighbor-changes
  network 172.17.3.0 mask 255.255.255.252
  neighbor 172.17.3.2 remote-as 12000
  no auto-summary
…......... and Hampton, VA as:
interface Tunnel1
  bandwidth 1024
  ip address 10.250.250.1 255.255.255.0
  no ip redirects
  ip mtu 1472
  ip nhrp authentication SPOKHAM
  ip nhrp network-id 50001
  load-interval 30
  delay 1000
  keepalive 10 7
  tunnel source 172.17.3.25
  tunnel key 50001
  hold-queue 4096 in
  hold-queue 4096 out
interface Tunnel2
bandwidth 1024
ip address 10.250.200.25 255.255.255.0
no ip redirects
ip mtu 1472
ip nhrp map multicast 172.17.3.1
ip nhrp map 10.250.200.1 172.17.3.1
ip nhrp nhs 10.250.200.1
delay 1000
qos pre-classify
keepalive 10 4
tunnel key 10002
router eigrp 250
  network 10.250.250.0 0.0.0.255
   network 172.22.250.25 0.0.0.0
  no auto-summary
router bgp 1750
  no synchronization
  network 172.17.3.24 mask 255.255.255.252
  neighbor 172.17.3.26 remote-as 12000
  no auto-summary
….BUT that Hampton Tunnel2 is basically making Hampton a spoke of Atlanta.  If I configure my other hub sites (Indiana and Washington) like the Hampton Tunnel above, they’ll be dependent on Atlanta being UP all the time in order to keep the 10.250.200.x DMVPN tunnel alive.
Now… When I change the Hampton’s Tunnel2 to look like:
interface Tunnel2
bandwidth 1024
no ip redirects
ip mtu 1472
no ip next-hop-self eigrp 250 (is this needed?  It doesn’t work right even when removed)
load-interval 30
delay 1000
qos pre-classify
keepalive 10 7
tunnel key 10002
hold-queue 4096 in
hold-queue 4096 out
I get no EIGRP routes between Hampton and Atlanta which basically is saying it not working (I assume).
Both Atlanta and Hampton have spokes that utilize their respective Tunnel 1 interfaces.  The spokes are not meant to talk to other spokes BUT the HUBs can/should be fully meshed.
What am I doing wrong?  Thanx!
Giuseppe Larosa Tue, 03/23/2010 - 13:16
  • Hall of Fame,
    Founding Member
Hello Rkendrick,
to connect the two hub routers you need to use something different from the DMVPN clouds themselves !!!
if the two devices are not connected via internal links you can use a distinct point-to-point GRE tunnel between them where you can run your routing protocol over it.
A term used in DMVPN context is daisy-chaining of hub routers
see
http://www.cisco.com/en/US/docs/ios/12_4t/12_4t11/ht_nhrp.html
and this networkers slides
http://www.cisco.com/en/US/prod/collateral/vpndevc/ps6525/ps9370/ps6658/prod_presentation0900aecd80313ca9.pdf
Hope to help
Giuseppe
