03-23-2010 12:50 PM - edited 03-15-2019 09:55 PM
Anyone have the instructions on how to download a CoreDump file via the CLI using the file get and an SFTP server? I assume these files are being store in the activelog folder but when I issue the following command from the CLI
file list activelog *.*
it returns 0 files and 0 directories.
I know you can also use RTMT to collect the crash dumps but I would rather use the CLI. You can view the core dump files on the server using
utils core active list
How do I download it using file get???
Solved! Go to Solution.
03-23-2010 03:14 PM
Not sure about that specific file, but my method for finding things is like so:
File list activelog /
Will list you the root folders, you can then append them and repeat:
File list activelog /cm/
Etc...
If you really struggle to find something that way, you can try :
File search activelog * aaron recurs ignorecase
To search all files for instances of 'aaron' - one trick is to pull the file via RTMT, and then open it and find a string in it you can search for.... then find it via the CLI and you'll know where it is next time.
Would be nice if there was a document telling you where everything was...
I guess what you are looking for would be somewhere in:
File list activelog platform/
Once you find it, I find that file get can be a bit picky about which SFTP servers it will write to... but the above should get you started...
Aaron
Please rate helpful posts...
03-23-2010 03:14 PM
Etc...
Aaron
03-23-2010 03:33 PM
Hey thanks Aaron, that's exactly the clue I needed. Now I can see all the folders.
03-23-2010 03:46 PM
Happy to help...
Please don't forget to rate helpful replies and mark answered threads you are happy with!
Aaron
