RVS4000 - Static Host Translation
apantoja
Where do you set up a Static host translation?  let's say (for example) the public address is 64.233.169.147 and I need to map it to 192.168.1.150  where do I set this?  I can then set the firewall rules to allow the specific inbound traffic?  Please help!
2 Accepted Solutions
1-to-1 NAT is not supported on RVS4000. Other small business routers such as RVL200 and RV042 support 1-to-1 NAT.
Port Forward Range (also under firewall) has inside address, but this is for specific ports.
Under firewall, there is 'Edit IP ACL rule" which can be done for services (existing or ones you define) and private inside IPs.
6 Replies 6
Steven DiStefano
Firewall: Port Forwarding Range
apantoja
I mean more like:   ip nat inside source static 192.168.1.254 x.x.87.171 route-map IP_NAT_STATIC_ROUTEMAP_1 extendable
I have a couple of servers on the LAN and I need to make sure there are static maps for each of the servers.  The port forwarding doesn't seem to have a place to put the public to the private address - I have a /29 available to me and I want to have some static mappings.  I do not want to port forward the IP address of the firewall (RVS4000).
Thanks!
so for the time being, until I purchase a Cisco RVL200 4-Port SSL/IPsec VPN Router, I will just port forward and allow the default firewall rules of any, any.
Thank You.
apantoja
I was disappointed to find out the RVS 4000 will not do 1:1 NAT. But at least I know the RVL200 will.
