03-23-2010 06:03 PM
Hi Team,
Is the power transformer included in the power adatper on SD205 ? Or it is inline within the switch ?
What is the dimension for the power transformer ?
Henry
03-24-2010 11:00 PM
Would anyone be able to help please ?
03-25-2010 07:55 AM
When you ask for the 'power transformer' are you referring to the power adapter? Here is a link that describes the contents of the packages and some dimensions.
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps10007/ps10009/data_sheet_c78-501967.pdf
The power adapter quite small and simply plugs into the wall. A thin cord then plugs into the SD205.
HTH,
Andrew Lissitz
03-25-2010 03:11 PM
Hi Andrew,
Thanks for your information. The customer is looking for the specific dimension of the power adapter. Is there any information available on that ?
Henry
