PEAP with Local EAP - Possible to export Controller certificate to client?
Mar 23rd, 2010
Looking at deploying 7925G's using 802.1x PEAP authentication. The phones will be authenticated by the wireless LAN controllers.
I'd like to enable the "Validate Server Certificate" option on the phones, that requires me to download the certificate from the authentication server (the WLC) I just want to use the built in cert in the controller.
Is it possible to export the cert from the controller to the phone? If so - how?
TIA
talmadari Wed, 03/24/2010 - 01:21
AFAIK it isn't possiable to import server certificate from the controller.
Trending Topics - Security & Network
