yjdabear Wed, 03/24/2010 - 10:52
What is the context of the "primary or secondary" you're referring to? In HSRP or something else?
yangrish Wed, 03/24/2010 - 11:34
Thanks for responding.
Yes, I looked into the CISCO-HSRP-MIB. Using, oid 1.3.6.1.4.1.9.9.106.1.2.1.1.11., I can get the primary IP address. Using this I can determine which IP block is primary and which is secondary.
However, I would like to be able to determine if the IP address configured on an interface is primary or secondary if HSRP is not configured.
CISCO-IP-IF-MIB seems to be able to do it, however, I see no support for it on the ASRs.
Yogi
yjdabear Thu, 03/25/2010 - 09:13
Is ciiIPAddressCategoryCap the OID you're referring to when you say "CISCO-IP-IF-MIB seems to be able to do it"? That answer notwithstanding, here's a little thinking-out-loud:
I don't know to what extent you want to rely on SNMP. I think you could simply use SNMP or some other means to pull off the entire IOS config, and parse it with Perl/sed/whatever on your local box.
Or, since you can already "determine which IP block is primary and which is secondary" with CISCO-HSRP-MIB, you could also poll "ipAdEntAddr / 1.3.6.1.2.1.4.20.1.1". By piecing those two together, maybe it could get you what you want.
Finally, if you know what you're looking for can be found with some combo of IOS "show" commands, I suggest posting in the other Network Management forum: https://supportforums.cisco.com/community/netpro/network-infrastructure/network-management, for a possible EEM-based solution.
yangrish Thu, 03/25/2010 - 17:30
Thanks for responding, yjdabear.
We will probably get the running config and work that way. Many thanks for the idea!
Yogi
Related Content
