Remote Access using VSAT
Mar 24th, 2010
Hie
I have three remote branches. We are thinking of setting up VSAT so that these branches can have access to our servers here at the HQ. The maximum number of users in these branches is 5 per branch. Now I need help on the setting up of the VPN. What sort of routers are suitable for the set up and do I need to set up Vsat at the HQ as well?
paolo bevilacqua Wed, 03/24/2010 - 17:02
  • Hall of Fame,
    Founding Member
You can use a very minimum of 851, but 871 are more indicated.
Check if you have 3G service that could a better option in which case you use 88x.
In any case you will need a network professional for a proper configuration and fine tuning.
