7200 input packet drops
Mar 24th, 2010
Hi ,
I am seeing input drops between cisco 7200 and cisco 6500.
Drops are increasing continuosly.
input queue: 0/1000/1512/0 (size/max/drops/flushes) total output drops=0.
I have already increased the hold queue value to 1000.
paolo bevilacqua Wed, 03/24/2010 - 02:32
  • Hall of Fame,
    Founding Member
You are not giving not nearly engough detail.
What config and features are you using ?
What NPE hardware ?
What traffic volume ?
What are the input and output interfaces ?
You must be accurate when reporting problems.
paolo bevilacqua Wed, 03/24/2010 - 16:46
  • Hall of Fame,
    Founding Member
Drop rate is insignificant compared to input counter.
Could have been traffic burst or other transient anomaly.
Keep monitoring, no other action is necessary.
Please avoid using attachments unless necessary.
GigabitEthernet0/1 is up, line protocol is up
  Hardware is BCM1250 Internal MAC, address is 0015.62d7.331e (bia 0015.62c7.331
b)
  Description: Internal Interface connected to Coresw
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
     reliability 255/255, txload 9/255, rxload 4/255
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, media type is RJ45
  output flow-control is unsupported, input flow-control is unsupported
  Last input 00:00:00, output 00:00:00, output hang never
  Last clearing of "show interface" counters 16:35:35
  Input queue: 0/1000/1512/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 18364000 bits/sec, 6182 packets/sec
  5 minute output rate 37688000 bits/sec, 6802 packets/sec
     358228425 packets input, 586643626 bytes, 0 no buffer
     Received 1 broadcasts, 0 runts, 0 giants, 0 throttles
     0 input errors, 0 CRC, 0 frame, 778 overrun, 0 ignored
     0 watchdog, 116497 multicast, 0 pause input
     328847041 packets output, 920655466 bytes, 0 underruns
