ACS Replication
Mar 24th, 2010
I currently trying to set up replication between two ACS servers (installed on windows) both running software version 4.2.1.15.
The replication completes ok (as shown in the logs on both servers), but the replicated config is not showing on the secondary server.
So for example - I have 'Network Configuration Device Tables' checked on both servers (send on primary / receive on secondary), but these configured devices do no show under 'Network Configuration' when the replication has completed.
Has anyone seen this issue before? or is there something I am missing here?
Kind Regards
Terry
Javier Henderson Wed, 03/24/2010 - 12:05
Set the log level detail to full (System Configuration -> Service Control) and restart the services, then replicate again, and then look at the log files in the ACS services directories, in particular CSAuth.
