Multiple internet connection
Shibu1978
Dear All,
Please find attached the new setup we are planning to implement in our office.
1.2-Internet connections  ( ADSL + Leased line both will have fixed ip addressess)
We plan to send out the users browsing traffic to ADSL link back up should be via leased line... all servers traffic should be send out via leased line first and ADSL as backup.
By looking at our diagram could u please help us to implement our requirement with the attached diagram.
6 Replies 6
Shibu1978
Can you please someone reply on to my mail...is it possible ?
Shibu
Yes, it is possible.
Recommend you work with a certified partner ot reputable consultant to achieve the result wanted.
Thanks for your reply.
Meantime could you please get me some useful links so that i can try and make it implemented as i cant engage cisco partner at this time.
Shibu
Shibu1978
Dear All,
Could you please someone guide me to configure my requirement .
thanks
first of all the requirements you want is possible, but by comparing your current network diagram and the requirements you looking to achieve i think its a bit complicated, because according to your requirements you need a policy based routing with IP SLA to get the traffic routed based on traffic source
but the problem is you have the firewall is sitting in the central point between your edge routers and firewalls can not do PBR
it can be resolved using couple of ways such as multiple context in the firewall and so on .. but you need to keep it as simple as possible
i think one of the simple ways is to have a third router to be placed infront of the firewall and the routers will connect to this router in this case you will configure this new router as the PBR router to send the traffic based on source to the desired ISP/router
bellow is a configuration example that help you to understand and configure the third router suggested above
by the way if you think that adding a third router infront of the firewall will make single point of frailer,  i think you already have this issue by having one firewall
https://supportforums.cisco.com/docs/DOC-8313
good luck
if helpful Rate
Dear,
Thanks for your kind reply.
As u suggested i can not get one more router in between to configure PBR. one of the edge router is a cisco integrated router 2801 which will support PBR config I guess.....could you please confirm whether it support to configure PBR on the integrated 2801 router.
thanks
