What is the reason of this state of E1 R2 : R2_Q421_BLOCKED
Mar 24th, 2010
What is the reason of this state : R2_Q421_BLOCKED.
I explain :
We use a 2800 as a voice-gateway, connected to a MSC Huawei (R7). IOS 12.4-11-T2
This message appears after that the Huawei side end the call.
The channel is still  blocked during 2 minutes. Imagine that there are 50 users.
When cucm users end the call, then message become IDLE, but the Huawei side display that the channel is still used.
Have you any idea about the message R2_Q421_BLOCKED? What is the reason? Is there any issue?
This is the conf of the E1 ports :
controller E1 0/2/0
framing NO-CRC4
clock source internal
ds0-group 0 timeslots 1-10 type r2-digital r2-semi-compelled ani
ds0-group 1 timeslots 11-15,17-31 type r2-digital r2-semi-compelled ani
description R2 to Huawei
controller E1 0/2/1
framing NO-CRC4
ds0-group 0 timeslots 1-15 type r2-digital r2-semi-compelled ani
ds0-group 1 timeslots 17-31 type r2-digital r2-semi-compelled ani
controller E1 0/3/0
framing NO-CRC4
ds0-group 0 timeslots 1-15,17-31 type r2-digital r2-semi-compelled ani
Best regards
Overall Rating: 5 (1 ratings)
paolo bevilacqua Wed, 03/24/2010 - 06:41
  • Hall of Fame,
    Founding Member
Why don't you configure both boxes for PRI and live happy then.
marcos.mega Wed, 01/04/2012 - 16:00
Hola, apenas hoy yo tube un problema igual con un gateway cisco2901(
C2900-UNIVERSALK9-M):
XXXXXX#show voice call summ
PORT           CODEC     VAD VTSP STATE            VPM STATE
0/2/0:1.1       -          -  -                     R2_Q421_BLOCKED
0/2/0:1.2       -          -  -                     R2_Q421_BLOCKED
0/2/0:1.3       -          -  -                     R2_Q421_BLOCKED
0/2/0:1.4       -          -  -                     R2_Q421_BLOCKED
0/2/0:1.5       -          -  -                     R2_Q421_BLOCKED
0/2/0:1.6       -          -  -                     R2_Q421_BLOCKED
0/2/0:1.7       -          -  -                     R2_Q421_BLOCKED
0/2/0:1.8       -          -  -                     R2_Q421_BLOCKED
0/2/0:1.9       -          -  -                     R2_Q421_BLOCKED
0/2/0:1.10      -          -  -                     R2_Q421_BLOCKED
Intentamos varias cosas, reiniciar el "voice-port 0/2/0:1", reiniciar y reconfigurar la interfáz "controller e1 0/2/0". Pero lo que dio solución a la falla fue reiniciar el CPE; antes de reiniciar el router, observamos que la NTU estaba alarmada pero ésta era alimentada remotamente. Una vez reiniciado el router los puertos se observaron de la siguiente manera:
RRSCOxxxxx6(config)#do show voice port summ
                                           IN       OUT
PORT            CH   SIG-TYPE   ADMIN OPER STATUS   STATUS   EC
0/2/0:1         01  r2-digital  up    dorm idle     idle     y
0/2/0:1         02  r2-digital  up    dorm idle     idle     y
0/2/0:1         03  r2-digital  up    dorm idle     idle     y
0/2/0:1         04  r2-digital  up    dorm idle     idle     y
0/2/0:1         05  r2-digital  up    dorm idle     idle     y
0/2/0:1         06  r2-digital  up    dorm idle     idle     y
0/2/0:1         07  r2-digital  up    dorm idle     idle     y
0/2/0:1         08  r2-digital  up    dorm idle     idle     y
0/2/0:1         09  r2-digital  up    dorm idle     idle     y
0/2/0:1         10  r2-digital  up    dorm idle     idle     y
RRSCOTI-TAM01A-70226(config)#
Y las llamadas se pudieron establecer sin problemas.
paolo bevilacqua Thu, 01/05/2012 - 04:30
  • Hall of Fame,
    Founding Member
You should update IOS, because if it happened once, it will likely happen again.
