ā03-24-2010 05:51 AM - edited ā03-15-2019 09:56 PM
I've got Unity Express 7.1 configured on a router and just need some help in understanding the call in numbers and call handling numbers that are located in Unity Express.
I have 3 CTI RP's 5000, 5001 and 5002 confgiured in UCM (along with 8 standard CTI ports) that are allocated for Unity Express.
Now my questions is this:
In Unity Express > System:Call-in Numbers I have 5000 configured for voicemail, 5001 for autoattendant and 5002 for promptmanagement - is this correct should these numbers refer to the CTI RP in UCM ?
Secondly:
In Unity Express > Voice Mail:Call Handling - What numbers should I give out for Voice Mail Phone Number, Voice Mail Operator Number and Administration via Telephone Call-In number??? do I allocated the same numbers as above (CTI RPs) or should I allocate new numbers say 6000, 6001 and 6002 ??
Sorry but the documetation is a bit vauge and I am getting a little confused.
Rod
Solved! Go to Solution.
ā03-24-2010 07:15 AM
Hi Rod,
Good questions
Yes, the numbers assigned = 5000 configured for voicemail, 5001 for autoattendant and 5002 for promptmanagement should refer to the matching CTI RP in CUCM . The are the "access points" to each of these areas within QUE.
Voice Mail Phone Number = 50000
Voice Mail Operator Number = the DN of the Admin person who will handle Dial 0 requests
Administration via Telephone Call-In number = 5002
There are some great tips/examples in this doc;
CallManager for Cisco Unity Express Configuration Example
Hope this helps!
Rob
Please support CSC Helps Haiti
Hi Rod,
Good questions
Hope this helps!
Rob
ā03-24-2010 07:54 AM
Rob - many thanks.
Just to clear things up:
You say 5002 for the administration via telephone - This ties in with the CTI RP 5002 correct?
Also do I need to set up a translation pattern that matches an external DDI number and match it to a call party transformation mask pointing to 5002? as I assume this allows users to call from a PSTN to check their voicemail?
Rob - One thing other thing - do I point the UCM voicemail pilot number to 5000 ro 50000 ?
Thanks again
Rod
ā03-24-2010 08:42 AM
Hey Rod,
No worries my friend
For each of these numbers; 5000,5001 and 5002 you will want to either use a DDI or
a matching translation so that the numbers can be accessed remotely. If you have "spare"
DDI #'s it's always easiest to just use them for these functions.
5000 (which will be the VM Pilot#) - so users can check their VM from offsite.
5001 for caller access from PSTN to AA
5002 for AVT (changing VM/AA prompts from offsite)
Cheers!
Rob
