Upgrading Exchange 2003 to 2010 (Unity 4)
Mar 24th, 2010
I just had a quick question about upgrading my current Exchange 2
003/Unity4 setup.  Should I upgrade to all the newest Unity/CCM and then upgrade the server?  Or should I upgrade the Exchange 2003 server first and then upgrade Unity and CCM?  Links would be helpfel, thanks.
Overall Rating: 4.2 (5 ratings)
David Hailey Wed, 03/24/2010 - 07:37
To add-on, Unity 4x only supports Exchange 2000/Exchange 2003.  Unity 5x and above support Exchange 2007 and/or Exchange 2003.  In a mixed-mode integration, Unity needs to leverage the Exchange 2007 server as the primary mailstore.  So, you would need to update the UC environment before making any upgrades to Exchange.
Hailey
Please rate helpful posts!
wisdum1010 Tue, 03/30/2010 - 13:36
Thanks for everyone's responses.  I have decided to change out my Exchange 2003 server for different hardware.  I was doing some reading and I saw that
I can just add another Exchange 2003 server to my current one and move mailboxes over.  I also read that I can change Unity Partner Server to the new Exchange server.
My question now is do I move the mailboxes first and then change the partner server?  Or do I change the partner server setting first and then move mailboxes?  Here is a link to what im reading:
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/42/upgrade/guide/ex/ru_060.html#wp1126479
I'm just running into an issue with a dying server that desperately needs to be replaced.  Plus, it holds me over long enough to upgrade my phones (and then exchange).
Aaron Harrison Tue, 03/30/2010 - 13:40
The important bit isn't when you partner to the new server, so much as that you run the Perms Wiz to set up the permissions on the mailstore on the new server before you move any mailboxes or change the partner server.
Aaron
wisdum1010 Tue, 03/30/2010 - 14:21
I am having a hard time finding information on the Permission Wizard... I found a site but it is going over initial setup with Exchange 5.5/2000.
  Its all the same AD and Exchange environment, is that still neccesary?
David Hailey Tue, 03/30/2010 - 14:23
Yes, you need to re-run the Permissions Wizard to get rights on the new Partner Server. Go to www.ciscounitytools.com and look for Permissions Wizard. The most recent help file is contained there.
Hailey
Aaron Harrison Tue, 03/30/2010 - 14:27
Yep - you're adding a new mailstore when you set up the Unity server initially. You're adding a new mailstore now, so you need to assign the rights to those stores...
Aaron
Related Content
