CUC 7.0 - error Domain name is not valid
Mar 24th, 2010
I tried to entered in the Web admin page of the Unity Connection the smtp domain : cuc7lab.7lab.csb.etg.ca and I always get an error Domain name is not valid. If I change for cuc7lab.aaa.csb.etg.ca, it is ok.
cuc7lab is the host name
7lab.csb.etg.ca is the domain
If put anything without a number in the domain, I did not get that error.
I really do not understand.
Thanks,\
rob.huffman Wed, 03/24/2010 - 08:59
Hi Celine,
It may be this restriction;
The complete domain name used by Connection cannot be a subset of the domain name used by the remote voice messaging system. For example, if Connection is using the domain name cisco.com, the remote voice messaging system cannot use names like london.cisco.com, paris-cisco.com, or romecisco.com. However, you could use europe.cisco.com for Connection, and then use the names london.cisco.com, paris-cisco.com, and romecisco.com for the remote voice messaging systems.
http://www-europe.cisco.com/en/US/docs/voice_ip_comm/connection/2x/administration_cmbe/guide/6xcucmbesag250.html#wp1049860
Cheers!
Rob
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
https://supportforums.cisco.com/docs/DOC-8727
David Hailey Wed, 03/24/2010 - 10:37
Celine,
Admittedly, I dont 100% follow what you're trying to do.  Are you trying to change the SMTP domain of the CUC server to match the domain name of the server or were you trying to access the server's web pages using the SMTP domain vs. the domain name (or IP) of the server?
Hailey
Please rate helpful posts!
