03-24-2010 12:22 PM - last edited on 03-25-2019 07:57 PM by ciscomoderator
I have a question, is there a way to centralize voicemail with CUE, what i mean is we have 3 sites all running CCME version 7. the customer would like to have centralized voicemail, the main site has CUE & CME. is this possible ?
thanks
Solved! Go to Solution.
03-24-2010 12:51 PM
Yes, this is supported with CUE 3.2 and later on an NME-UCE with up to 10 remote sites.
Hope this helps.
Brandon
03-24-2010 12:51 PM
Hope this helps.
Brandon
03-24-2010 01:07 PM
it does help. thank you very much
Besides that doe, do you have a document that will show how to configure it ? tell you what needs to be done to accomplish this ?
