Questions with CiscoRVS4000
Mar 24th, 2010
We bought 2 CiscoRVS4000 for our branch offices and they work great. I have the following Questions:
1. is there a CLI to the box?
2. What is the latest published firmare?
3. I found a bug int the software. See attached image. Remote managment is enabled but wont allow me to disable it. Same with the HTTPS port. I cant seem to make it not allow remote management. Any solution?
4. I am runinng STAR 9202 CPU and V1.3.1.0 firmware.
Please let me know.
Thanks!
Michael010 Wed, 03/24/2010 - 13:38
I can't help you with much of it unfortunately!
You are running the latest published firmware according to the Cisco site.
Are they creating a VPN connection between them? That might explain why you can't disable some of the features.
Cheers
nealrfildes Thu, 03/25/2010 - 05:57
not speaking officially, it appears you have the latest firmware and that CLI is not supported.
hopefully more firmware is coming as there are still quite a few open issues.
nrf
yraunaj52 Fri, 03/26/2010 - 06:15
It might be effective to access the RVS4000 interface with a different browser.
Instead of Interent Explorer, try changing settings with Firefox. The RVS4000
has intermittent issues when accessed via Internet Explorer - changing settings
and saving the changes reliably, upgrading signature file, etc. all work better
using Firefox.
I have no idea if this is the cause of the remote access snafu but as a general
rule forget about operating the RVS4000 with IE - Firefox works much better.
