Warning message
QoS Question
Mar 24th, 2010
Hi folks:
3550 switch running 12.2.35 SE5
Have this QoS config:
ip access-list extended DATA
  permit udp any any eq netbios-ns
  permit udp any any eq netbios-dgm
  permit udp any any eq netbios-ss
  permit tcp any any eq telnet
  permit tcp any any eq www
  permit tcp any any eq 443
  permit tcp any any eq 22
  permit tcp any any eq ftp
class-map match-any DATA_CLASS_MAP
  match access-group name DATA
policy-map SET_DSCP_MICROSOFT_TRAFFIC
  class DATA_CLASS_MAP
   set dscp af41
interface FastEthernet0/3
switchport access vlan 10
switchport mode access
speed 100
duplex full
service-policy input SET_DSCP_MICROSOFT_TRAFFIC
I plugged my laptop into fa0/3 and generated all kinds of traffic to match the ACL for the class map...ran some telnets, pings, opened windows explorer, ran telnet on port 80, etc...
But I get no hits on the service policy on that interface:
Switch1#sh policy-map  interface fa0/3 input
FastEthernet0/3
  Service-policy input: SET_DSCP_MICROSOFT_TRAFFIC
    Class-map: DATA_CLASS_MAP (match-any)
      0 packets, 0 bytes
      5 minute offered rate 0 bps, drop rate 0 bps
      Match: access-group name DATA
        0 packets, 0 bytes
        5 minute rate 0 bps
    Class-map: class-default (match-any)
      0 packets, 0 bytes
      Match: any
        0 packets, 0 bytes
        5 minute rate 0 bps
3550#
How come?
Overall Rating: 5 (1 ratings)
visitor68 Wed, 03/24/2010 - 13:00
3550#show mls qos interface fa0/3 statistics
FastEthernet0/3
Ingress
  dscp: incoming   no_change  classified policed    dropped (in bytes)
Others: 0          0          0          0          0
Egress
Others: 0             n/a       n/a      0          0
3550#
Nothing......
visitor68 Wed, 03/24/2010 - 13:17
Not stupid at all...I forgot to enable qos...
Now that I did, this is what I get:
3550#SH POLICy-map interface fa0/3 input
FastEthernet0/3
      0 packets, 0 bytes
        0 packets, 0 bytes
        5 minute rate 0 bps
      0 packets, 0 bytes
      Match: any
        0 packets, 0 bytes
        5 minute rate 0 bps
3550#
3550#
3550#
3550#
FastEthernet0/3
Ingress
Others: 262        0          262        0          0
Egress (??)
Others: 6283          n/a       n/a      0          0
3550#
I didnt set any egree policy......and I dont understand how to read this output..and it also seems to contradict the first command output...
Lei Tian Wed, 03/24/2010 - 13:17
  • Cisco Employee,
Hi ex-engineer,
You need to
1, make sure qos is enabled.
2, configure mls qos monitor dscp 34 under the interface, and use the above command to check if traffic been marked to af41.
HTH,
Lei Tian
visitor68 Wed, 03/24/2010 - 13:29
FastEthernet0/3
Ingress
    34: 0          0          0          0          0
Others: 522        0          522        0          0
Egress
    34: 0             n/a       n/a      0          0
Others: 40299         n/a       n/a      0          0
thanks
I still dont understand how to interpret these statistics...what is this telling me?
visitor68 Wed, 03/24/2010 - 13:32
And why no stats using this command
sh policy-map int fa0/3 input
FastEthernet0/3
      0 packets, 0 bytes
        0 packets, 0 bytes
        5 minute rate 0 bps
      0 packets, 0 bytes
      Match: any
        0 packets, 0 bytes
        5 minute rate 0 bps
Lei Tian Wed, 03/24/2010 - 13:56
  • Cisco Employee,
The QoS marking and ACL are done by hardware, or the ASIC. The show policy-map interface will not be able to capture the counter correctly, same is true for 3750s. This is one of the gotcha on these platform.
Regrading the meaning of the output,
incoming: number of packets enter this interface that have dscp 34
no_change: number of packets keep dscp 34 after qos process
classified: number of packet been classified to dscp 34
For your case, your output shows none packet been marked as af41.
HTH,
Lei Tian
r.shummoogum Wed, 03/24/2010 - 13:40
The packets are coming in with a DSCP other that 34 and is getting marked at the ingress. That is why it zero everywhere and non-zero for other.
