VPN Client Command Line Configuration for UC500
Answered Question
Mar 24th, 2010
Hi all, I have a Cisco UC500 at a site and I need to set up VPN Client for users to remote in. The Configuration Assistant has an easy set up however, it errors out when try to save it. The error refrences that the outside interface has been partially configured via the command line.
So I would like to try to set this up via the command line however, I cant find any doc's on it all I find are for routers, ASA's, and Pixs. Any one have a walk through on setting this up via the command line?
thanks,
Dan
Correct Answer by Jennifer Halim about 7 years 3 days ago
VPN Client configuration on UC500 is the same as router. You can use the same sample configuration for routers.
Overall Rating: 5 (1 ratings)
Correct Answer
Jennifer Halim Wed, 03/24/2010 - 20:25
  • Cisco Employee,
Related Content
