Video on 9971
Mar 25th, 2010
Hi everyone,
I try to make my 9971 work in a video call.
I have CUCM 7.1.3.32900-4, DevicePack 7.1.3.32010-1 and firmware 9.0(2).
I enabled Cisco Camera on the Enterprise Phone Configuration page with Override Common Settings but I can't even get one-way video.
I don't have any Video parameters on the CUCM page Phone Settings on the 9971, that's odd.
Did I misse something?
I didn't reboot the CUCM cluster but in CUCM 6.1.2, each time I upgraded the device pack or firmwares, I had more options without rebooting someting else than the phone.
Overall Rating: 5 (2 ratings)
FRANZ EDUARD PE... Mon, 04/19/2010 - 07:36
try the new devicepack that came out on 16.4, with this you should get the option to enable video.
br
lusandi Sun, 05/09/2010 - 14:00
  • Bronze, 100 points or more
Dowload the latest device pack for your call manager version that will fix your problem.
Luis Sandi
Novriadi . Tue, 10/05/2010 - 21:44
Hi All
I'm running CUCM 7.1.3.32900-4 in my customer environment and registered new 9971 (SIP) with phone loads sip9971.9-0-4.loads.
I've already enabled Cisco Camera in Product Specific Configuration Layout in Enterprise Phone Paramater, but until now I can only preview video in IP Phone 9971.
How to run video call on 9971 SIP ? anyone can help or have same experience ?
Novri
FRANZ EDUARD PE... Wed, 10/06/2010 - 04:39
Check your setting within our "region" (Max Video Call Bit Rate (Includes Audio) - 384 should be okay here) and "location" (Video Calls Information).
br
Novriadi . Wed, 10/06/2010 - 15:47
Hi Sajjit
I've only test with 9971, but it's not work, The IP Phone detect the camera and also can preview the camera, but If I Unplugged and then plugged the camera again on the screen of IP Phone said that The Administrator disabled the camera.
is there any configuration i'm missing ?
thanks
Novri
Novriadi . Mon, 10/11/2010 - 21:03
Hi All
This problem solved with install the latest device pack to my CUCM Cluster.
Jamil Hussain Sun, 01/23/2011 - 23:34
Dear Novriadi,
I am also facing the same problem and i have Cisco Unified CM Administration System version: 7.1.3.21900-4.
I am trying to make a video call between two cisco ip phones 9971 and Active Load is sip9971.9-0-3.loads.
Could you please tell me which latest device pack you installed on your CUCM Cluster to fix this problem.
Waiting for your reply.
Thanks.
Novriadi . Mon, 01/24/2011 - 00:48
Hi Jamil
I'm using cmterm-devicepack7.1.3.33024-1.cop.sgn for activate feature video call on 9971.
thanks
Jamil Hussain Mon, 01/24/2011 - 01:03
Dear Novriadi,
I want to confirm one thing that currently I am running System version: 7.1.3.21900-4 and active load on 9971 is sip9971.9-0-3.loads this is not supporting Video calls on 9971.
And in order to work video call I have to upgrade device pack the one which you mentioned in your email.
Novriadi . Mon, 01/24/2011 - 01:31
Dear Jamil
Since in System version: 7.1.3.21900-4 with active load on 9971 is sip9971.9-0-3.loads not shown option to enabled video call on 9971 Device,  U must upgrade to device pack like I mention before.
Actually on  System version: 7.1.3.21900-4 with active load on 9971 is sip9971.9-0-3.loads, enable video option not shown on Phone Configuration.
After u install the device pack, u can choose the option to enabled video.
thanks.
Jamil Hussain Mon, 01/24/2011 - 01:33
Thanks a lot Novriadi
I will install the latest device pack.
Jamil Hussain
