CUE Web Interface isnt working.
Mar 25th, 2010
Hi Friends,
I've a Cisco 3845, on which I am running CME/CUE (CUE Module is NM_CUE). Call Manager Express I can access the GUI & the configurations can be done however the same is not possible with CUE.
CUE IP : 172.17.2.7 (IP unumbered to Gigabit Eth 0/0 which is 172.17.2.6 - CME IP);
http://172.17.2.7/ or http://172.17.2.7/Web (I dont get any pages)
Show config (From CME & CUE is attached)
I have reloaded the CUE. Startup Logs for CUE module is also attached.
Your suggestions will be much Appreciated.
Sylvester
rocreditex Mon, 05/10/2010 - 20:04
Can you ping the cue from the workstation?
if not then you need to add a static route on the workstation or point the workstation to the CME as default gateway.
Related Content
