3750 Switch Module xmodem help
jordanjd
I have a 3750 switch module in a 3825 router chassie. I have lost the IOS on the switch module. The router IOS is fine and work. I can only connect to the switch module using the service module gig 2/0 session command. I have tried to xmodem the IOS to the switch using the xmodem commands (THIS DOES NOT WORK).  I know that my session into the switch is "quazi" IP base and my xmodem is serial base using the router console port.  How do I get a serial connection (my IOS for the switch) over to the switch when my connection to the switch is "IP" I am assuming. I know there has be to way.
thanks
Leo Laohoo
I have never seen this before!  I can only think of contacting the TAC and get the module RMA-ed.
jordanjd
Ok I can not take credit for this. One of guys at my shop found it.   You copy the switch IOS to the router flash. Next issues the "copy flash: xmodem:" command, then follow and answer the prompts....He found the answer in a Cisco doc using "3750 xmodem via 3825 router" search....
Jimmy
Hello Jimmy,
you are probably referring to
http://www.cisco.com/en/US/docs/ios/12_3t/12_3t14/feature/guide/miragenm.html#wp1768057
this can be a useful tip for other people having the same issue.
Moving the IOS image into the router flash could be guessed as the only logical step to do.
To be noted that in a multilayer device like C6500 to move images to service modules ip addresses like 127.0.0.x are used.
So my guess was some form of TFTP from router to flash to module but in this case there is an xmodem: filesystem to be used as destination.
Hope to help
Giuseppe
