Error NEXUS 5000 power supply - %NOHMS-2-NOHMS_ENV_ERROR
Mar 25th, 2010
hi all,
i get, after i allready changed the power supply, the same error message again.
2010 Mar 24 20:03:53.271 L4DE8NSY523 %NOHMS-2-NOHMS_ENV_ERROR: Module 1 temperature sensor PS-1 failed.
2010 Mar 24 20:04:23.333 L4DE8NSY523 %NOHMS-2-NOHMS_ENV_ERROR: Recovered: Module 1 temperature sensor PS-1 failed.
2010 Mar 24 21:38:27.285 L4DE8NSY523 %NOHMS-2-NOHMS_DIAG_ERR_PS_FAIL: System minor alarm on power supply 1: failed
2010 Mar 24 21:38:57.299 L4DE8NSY523 %NOHMS-2-NOHMS_DIAG_ERR_PS_RECOVERED: Recovered: System minor alarm on power sup
ply 1: failed
i do not find the error explanation in the error message decoder. now i guess that not the power supply is defect but the NEXUS 5010 itself. am i right ? please advise !
Cisco Nexus Operating System (NX-OS) Software
kickstart: version 4.1(3)N1(1)
system:    version 4.1(3)N1(1)
regards Reinhold.
Ming Tang Tue, 05/20/2014 - 23:32
that depends on what you see in "show env".
and how often you see the errors.
if ps shows " ok" in " show env". this is likely a cosmetic issue:
Please check  CSCub52503 for more detail.
rjust1965 Tue, 05/20/2014 - 23:53
Hi mitang.
thanks for answer. fortunately it stopped.
regards Reinhold.
