No LMS processes/License Server
Mar 25th, 2010
I've performed a fresh install of LMS 3.2 on to Server 2008 R1.
No processes are showing and in CS, under products installed I see the message for all products installed "unable to retreive (license server is down)"
This appears to be a botched install, but I dont know what could've caused this. Any ideas?
See attached screenshots
Martin Ermel Thu, 03/25/2010 - 04:58
  • Blue, 1500 points or more
when installing LMS 3.2 on win2k8 you should consider the following  issues mentioned in these threads:
manual setting of swap space:
https://supportforums.cisco.com/message/680507#680507
registry  keys may need to be manually set (BugID CSCtb17186)
https://supportforums.cisco.com/message/1328649#1328649
also set the temp and tmp variable for the system and administrator account to something short (like C:\tmp) and install the software when logged in as the LOCAL administrator;
Martin Ermel Thu, 03/25/2010 - 05:55
I would recommend to uninstall LMS and install it again with the before mentioned prerequisites (check the registry keys!)
I see some ERROR messages in the log file belonging to the databases along with RMEPSUAdapter failures and I would not proceed with this installation. The savest way would be to reinstall LMS.
from the log file:
===================- Possible Warnings/Errors Encountered -===================
Warning: Current swap space is less than the minimum requirement. This may affect performance.
WARNING: Domain Name is not found from TcpIp parameters,certificate will be generated with the HostName
WARNING: Domain Name is not found from TcpIp parameters, setting PX_FQDN same as PX_HOST
ERROR: Failed to authenticate [opsxml] database.
ERROR: Failed to Start Database 'opsxml' because: Database engine 'opsxmlEng' could not be started on database 'opsxml' in Bulk mode
ERROR: Failed to start database engine for database 'opsxml'
ERROR: Failed change password for database 'opsxml'.
ERROR: Failed to authenticate [rmeng] database.
ERROR: Failed to Start Database 'rmeng' because: Database engine 'rmengEng' could not be started on database 'rmengdb' in Bulk mode.
ERROR: Failed to start database engine for database 'rmeng'
ERROR: Failed change password for database 'rmeng'.
ERROR: Failed to authenticate [ipm] database.
ERROR: Failed to Start Database 'ipm' because: Database engine 'ipmEng' could not be started on database 'ipm' in Bulk mode.
ERROR: Failed to start database engine for database 'ipm'
ERROR: Failed change password for database 'ipm'.
ERROR: Failed to authenticate [upm] database.
ERROR: Failed to Start Database 'upm' because: Database engine 'UPMDbEngine' could not be started on database 'upm' in Bulk mode.
ERROR: Failed to start database engine for database 'upm'
ERROR: Failed change password for database 'upm'.
INFO: User Selected to Reboot the Machine
Installation Completed at 21:05:19 ,Wed 03/24/2010  ,Central Standard Time
and also this one:
line 5395 com.cisco.nm.xms.psu.interfaces.adapter.AdapterException: Failed to Initialize RMEPSUAdapter
