ASA 5520 - LU allocate xlate failed - Failover unit reloads
Mar 25th, 2010
We just had an issue with our failover unit reloading. In perusing the logs there were a number of %ASA-3-210007: LU allocate xlate failed, errors prior to the reload. These units had just had their OS upgraded to fix a DOS issue a few weeks ago. I have not seen the error since it reloaded. However, I was asked to report the issue just in case it is a bug in the new version of the OS.Two units in failover.
Cisco Adaptive Security Appliance Software Version 8.0(5)9
Device Manager Version 6.0(2)
Compiled on Mon 01-Feb-10 10:36 by builders
System image file is "disk0:/asa805-9-k8.bin"
Config file at boot was "startup-config"
CP-ASA up 17 days 21 hours
failover cluster up 17 days 22 hours
Hardware:   ASA5520, 512 MB RAM, CPU Pentium 4 Celeron 2000 MHz
Internal ATA Compact Flash, 256MB
BIOS Flash M50FW080 @ 0xffe00000, 1024KB
Encryption hardware device : Cisco ASA-55x0 on-board accelerator (revision 0x0)
                             Boot microcode   :  CN1000-MC-BOOT-2.00
                             SSL/IKE microcode:  CNLite-MC-SSLm-PLUS-2.03
                             IPSec microcode  :  CNlite-MC-IPSECm-MAIN-2.05
0: Ext: GigabitEthernet0/0  : address is 0025.45d7.6e62, irq 9
1: Ext: GigabitEthernet0/1  : address is 0025.45d7.6e63, irq 9
2: Ext: GigabitEthernet0/2  : address is 0025.45d7.6e64, irq 9
3: Ext: GigabitEthernet0/3  : address is 0025.45d7.6e65, irq 9
4: Ext: Management0/0       : address is 0025.45d7.6e66, irq 11
5: Int: Internal-Data0/0    : address is 0000.0001.0002, irq 11
6: Int: Internal-Control0/0 : address is 0000.0001.0001, irq 5
Licensed features for this platform:
Maximum Physical Interfaces  : Unlimited
Maximum VLANs                : 150
Inside Hosts                 : Unlimited
Failover                     : Active/Active
VPN-DES                      : Enabled
VPN-3DES-AES                 : Enabled
Security Contexts            : 2
GTP/GPRS                     : Disabled
VPN Peers                    : 750
WebVPN Peers                 : 2
AnyConnect for Mobile        : Disabled
AnyConnect for Linksys phone : Disabled
Advanced Endpoint Assessment : Disabled
UC Proxy Sessions            : 2
This platform has an ASA 5520 VPN Plus license.
I noted a report on errors with verison 7 and a conflict between nat(0) and static commands. I don't show nat(0) being used on these units.
nat (public) 0 access-list NO_NAT
nat (public) 1 10.190.16.64 255.255.255.192
nat (public) 1 172.16.22.0 255.255.255.0
nat (dmz) 0 access-list NO_NAT
nat (dmz) 1 0.0.0.0 0.0.0.0
nat (csacelb) 0 access-list NO_NAT
nat (csacelb) 1 0.0.0.0 0.0.0.0
nat (app) 0 access-list NO_NAT
nat (app) 1 0.0.0.0 0.0.0.0
nat (db) 0 access-list NO_NAT
nat (db) 1 0.0.0.0 0.0.0.0
nat (internal) 0 access-list NO_NAT
nat (internal) 1 0.0.0.0 0.0.0.0
nat (management) 0 access-list NO_NAT
nat (management) 1 0.0.0.0 0.0.0.0
no crypto isakmp nat-traversal
static (app,dmz) 10.190.15.0 10.190.15.0 netmask 255.255.255.192
static (csacelb,public) 999.999.999.999 10.190.14.70 netmask 255.255.255.255 (The external address was replaced with 999.999.999.999 intentionally for this forum)
static (db,app) 10.190.16.0 10.190.16.0 netmask 255.255.255.192
Related Content
