7600 SIP memory for full BGP
Answered Question
Mar 25th, 2010
I have to select a POS STM-1 (clearchannel) interface for a 7600 core router where I'll have 2 full BGP feeds + some partial feeds from public IX peering.
On the router I plan to have Sup 720-3BXL or maybe RSP720-3CXL with 16-port GE (WS-X6516A-GBIC) - no DFC; on the other side I have a 7200 with PA-POS-1OC3.
I'm evaluating to use a SIP (SPA Interface Processor) with a 2-port OC3/STM1 POS Shared Port Adapter (SPA-2XOC3-POS).
On SIP-200 and SIP-400 datasheets I can read thinks like this: "Memory default - 1 GB per Cisco 7600 SIP-400 - Enables support of large routing tables, rich QoS features, and increased scalability".
I can't understand how SIP memory would impact on routing table's capacity: aren't forwarding decisions made on the Sup/RSP? Do you see possible issues with the configuration I briefly summarized? Please enlighten me!
Many thanks
SIP-200 datasheet: http://www.cisco.com/en/US/prod/collateral/routers/ps368/product_data_sheet0900aecd8027c9df.html
SIP-400 datasheet: http://www.cisco.com/en/US/prod/collateral/routers/ps368/product_data_sheet0900aecd8027c9e6.html
Correct Answer by Giuseppe Larosa about 6 years 10 months ago
Hello Piercarlo,
SIP-600 connects to 720 Gbps switching fabric with a DFC 3BXL (and the memory size of DFC really counts in this case)
SIP-400 connects to switching fabric but without a DFC, so it should be similar to the use of a CFC.
Some sentences look like "marketing oriented" like in this case.
You should be fine with a SIP-400 we have two devices in a similar scenario and they work well.
We had an issue when replacing a WS-6708 10GE the replacement linecard arrived with the wrong DFC (DFC 3C instead of DFC 3XL) in that case it was a problem the module could not host in DFC memory the whole CEF table.
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Correct Answer
Giuseppe Larosa Thu, 03/25/2010 - 10:51
Hello Piercarlo,
Hope to help
Giuseppe
piercarlo.chiodi Fri, 03/26/2010 - 00:53
Many thanks Giuseppe, your experience is better than thousands of "marketing oriented" words!
Related Content
