ASA inside to dmz access
Mar 25th, 2010
Hello
Could someone give me a hand with INSIDE access to the DMZ interface? I've set this up in the past, and am unsure of the problem I am running into. I think that when a host access a server on the dmz, instead of a session being setup the outbound response is being nat'd and sent out the outside interface. Attached is the running config, and also below is a trace.
Also through debug icmp trace, i see an echo request when pinging the 172.16.0.1 DMZ interface from a host on the 172.16.72.0 INSIDE interface, but not a reply.
ASA# packet-tracer input inside icmp 172.16.72.7 1 1 172.16.0.1
Phase: 1
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Config:
Additional Information:
Found no matching flow, creating a new flow
Phase: 2
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   172.16.0.1      255.255.255.255 identity
Phase: 3
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
Phase: 4
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 5
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
Phase: 6
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
Phase: 7
Type: DEBUG-ICMP
Subtype:
Result: ALLOW
Config:
Phase: 8
Type: NAT
Subtype: host-limits
Result: ALLOW
Config:
static (inside,dmz) 172.16.72.0 172.16.72.0 netmask 255.255.255.0
  match ip inside 172.16.72.0 255.255.255.0 dmz any
    static translation to 172.16.72.0
    translate_hits = 0, untranslate_hits = 0
Phase: 9
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 889825065, packet dispatched to next module
Phase: 10
Type: ROUTE-LOOKUP
Subtype: output and adjacency
Result: ALLOW
Config:
found next-hop 0.0.0.0 using egress ifc identity
adjacency Active
next-hop mac address 0000.0000.0000 hits 26434041
Result:
input-interface: inside
input-status: up
input-line-status: up
output-interface: NP Identity Ifc
output-status: up
output-line-status: up
Action: allow
Jennifer Halim Thu, 03/25/2010 - 14:57
For ping to work, please configure the following:
policy-map global_policy
class inspection_default
     inspect icmp
Hope it helps.
bmurray2_home Thu, 03/25/2010 - 18:03
I don't see nat-control enabled within your config, but it seems like you're still trying to use nat.  I'm guessing you may either need to add nat-control, or get rid of the identity nat statements.  I'm not an "expert" though...  Good luck.
allenelson Fri, 03/26/2010 - 06:05
Hey guys
Thanks for the input.. I think the config is working out ok, the customer might have given me the wrong IP address to test with.. I'll post back once confirmed, thanks again.
