Port-channel(To use only some interface on the link)
Mar 25th, 2010
Hi All,
  Am trying to find a way,where only some members of the port-channel would be used until the load increase the active member capacity .If this is not possible,Also exploring a way to keep some member active and only other members become active when any or some of the active members link goes down .
Thanks for the help
Anantha Subramanian Natarajan
Overall Rating: 4 (1 ratings)
Giuseppe Larosa Thu, 03/25/2010 - 10:31
  • Hall of Fame,
    Founding Member
Hello Anantha,
you can have some hot standly links when using LACP
LACP allows to configure priority on a port basis
The device with the best system-id like an STP root bridge decides what links are active and what are placed in hot-standby state
see the section about hot standby links, they are used for redundancy only when one of the primary links fail (no load  level trigger)
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_44_se/configuration/guide/swethchl.html#wp1276329
Hope to help
Giuseppe
anasubra_2 Thu, 03/25/2010 - 12:03
Thank you Giuseppe
