Diable "Caller Input" in Unity Conn
Answered Question
Mar 25th, 2010
We are running Unity Connection 7.1.3.
We have a user that does not want the "caller input" to work at all.  If a caller is in Unity Conn and presses any digit, they want nothing to happen, just continue to play the greeting.
Is there a way to disable the "caller input keys"?
Trae
Correct Answer by lindborg about 7 years 4 days ago
almost... set it to ignore AND locked.  This casues Connection (or Unity) to ignore the key and throw it away without stopping the greeting...
Overall Rating: 5 (1 ratings)
Aaron Harrison Thu, 03/25/2010 - 09:47
  • Community Spotlight Award,
    Member's Choice, May 2015
If I recall correctly, you just set each action key to 'ignore'...
Aaron
Correct Answer
lindborg Thu, 03/25/2010 - 09:51
  • Cisco Employee,
Aaron Harrison Thu, 03/25/2010 - 10:04
Aha.. yes, all coming back to me now
