How can I set up a VPN with 1 cisco router?
Mar 25th, 2010
I have a remote branch I wish to connect to a VPN with our cisco router.  Which is the best protocol to do this?  How can I set it up?
andre.ortega Thu, 03/25/2010 - 10:48
  • Bronze, 100 points or more
  • Participante em Destaque,
    Escolha da Audiência, Maio de 2015
Yes, you can. And you can use IPSec (You nedd check your router (IOS) support IPSec.)
Do you need site-to-site vpn ou remote access (client to site)?
sgregory1 Thu, 03/25/2010 - 11:53
Show version reports:
Cisco IOS Software, 1841 Software (C1841-IPBASE-M), Version 12.4(1c), RELEASE SOFTWARE (fc1)
It would be from one site to this one, but there is no cisco router on the other end.  But this is the only link I need a VPN on
andre.ortega Thu, 03/25/2010 - 12:06
This IOS have not support for IPSec, and you need a device for each site, or users can use a client vpn.
See this link with example of the config VPN between router and ASA http://www.cisco.com/en/US/products/ps5855/products_configuration_example09186a0080a9a7a3.shtml
Regards.
sgregory1 Thu, 03/25/2010 - 13:21
What is this ASA? What I've done in the past is used cisco's VPN software on a windows machine to connect to a VPN.  Can I not set that up?
Remote site will connect with software to VPN server enabled on my router.  Is this possible? Is this what your link is meaning?
andre.ortega Thu, 03/25/2010 - 14:09
This is a sample only, for VPN site-to-site.
Do have your remote site another device (like ASA, router or a linux server)? If yes this device will connect in router.
If not the users can use a vpn client installed in computers.
Regards.
sgregory1 Thu, 03/25/2010 - 14:27
I have a problem with this.  It seems my route has no "crypto" command:
(config)#
#crypto ?
% Unrecognized command
(config)#crypto ?
EDIT: Our other router which is the same as this one has the crypto command.  a show version notes that the flash image is different!
Router not working:
System image file is "flash:c1841-ipbase-mz.124-1c.bin"
Router crypto is there:
System image file is "flash:c1841-advsecurityk9-mz.124-3g.bin"
sgregory1 Thu, 03/25/2010 - 15:52
Okay I have just finished updating the image and reconfiguring the router.  From the looks of this, I need to generate a key or something.  This is a bit confusing... for example the guide mentions hard-coding a static IP address on the client end.  My client is DHCP enabled... so is there another way I can configure this?
The "ASA" device... you say that can be any old router..? why is there a CLI shown?
andre.ortega Fri, 03/26/2010 - 05:24
See two samples:
      Site A                                   SITE B
LAN---ROUTER----INTERNET----ROUTER---LAN
SITE A
R0#sh run
Building configuration...
Current configuration : 1610 bytes
version 12.4
hostname R0
boot-start-marker
boot-end-marker
enable secret 5 $1$/Uap$KYw5T9RRj2Iqw7YRnybUp.
no aaa new-model
memory-size iomem 5
ip cef
crypto isakmp policy 10
authentication pre-share
crypto isakmp key cisco address 1.1.1.1 255.255.255.252
crypto ipsec transform-set teste_set esp-3des esp-sha-hmac
crypto map TESTE_MAP 10 ipsec-isakmp
set peer 1.1.1.1
set transform-set teste_set
match address ACL_VPN
interface FastEthernet0/0
description Conexao R2 F0/0
ip address 10.10.10.1 255.255.255.252
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial1/0
description Conexao com R1 S1/0
bandwidth 2048
ip address 1.1.1.2 255.255.255.252
serial restart-delay 0
interface Serial1/1
description Conexao com R1 S1/1
ip address 1.1.1.6 255.255.255.252
shutdown
interface Serial1/2
no ip address
shutdown
interface Serial1/3
no ip address
shutdown
router ospf 10
log-adjacency-changes
network 1.1.1.0 0.0.0.3 area 0
network 10.10.10.0 0.0.0.3 area 0
ip http server
no ip http secure-server
ip access-list extended ACL_VPN
permit icmp 0.0.0.2 255.255.255.252 host 10.10.10.6
permit icmp host 10.10.10.2 host 10.10.10.6
control-plane
line con 0
line aux 0
line vty 0 4
password cisco
login
end
SITE B
R1#sh run
Current configuration : 1571 bytes
version 12.4
hostname R1
boot-start-marker
boot-end-marker
enable secret 5 $1$zRJc$5ba6iIHxQzlIVZROagEWa0
no aaa new-model
memory-size iomem 5
ip cef
crypto isakmp key cisco address 1.1.1.2 255.255.255.252
set peer 1.1.1.2
ip address 10.10.10.5 255.255.255.252
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
interface Serial1/0
description Conexao com R0 S1/0
bandwidth 2048
ip address 1.1.1.1 255.255.255.252
interface Serial1/1
description Conexao R0 S1/1
bandwidth 128
ip address 1.1.1.5 255.255.255.252
shutdown
interface Serial1/2
no ip address
shutdown
interface Serial1/3
no ip address
shutdown
router ospf 10
network 1.1.1.4 0.0.0.3 area 0
network 10.10.10.4 0.0.0.3 area 0
ip http server
permit icmp host 10.10.10.6 host 10.10.10.2
control-plane
line con 0
line aux 0
line vty 0 4
password cisco
login
end
R1#
Second sample:
any place
USERS--- INTERNET----ROUTER---LAN
aaa new-model
aaa authentication login vpnauthen local
aaa authorization network vpnautho local
crypto isakmp policy 50
encr 3des
group 2
crypto isakmp client configuration group CANOPUS_GROUP
key c4n0pu5
domain canopus.com.br
pool VPN_POOL
include-local-lan
split-dns canopus.com.br
pfs
crypto ipsec transform-set CLIENT_SET esp-3des esp-md5-hmac
crypto dynamic-map CLIENT_MAP 50
set transform-set CLIENT_SET
reverse-route
crypto map CLIENT_VPN client authentication list vpnauthen
crypto map CLIENT_VPN isakmp authorization list vpnautho
crypto map CLIENT_VPN client configuration address respond
crypto map CLIENT_VPN 50 ipsec-isakmp dynamic CLIENT_MAP
ip local pool VPN_POOL 10.10.254.10 10.10.254.15
Regards.
DialerString_2 Fri, 03/26/2010 - 12:56
Wait... Steve are you setting up a site-to-site vpn or are you doing a remote-access (client)?  What devices do you have on each side? If one side is DHCP you can use Dynamic VPN to establish a connection. I have vpn setup over ADSL and can send you a sample config.
