H323 GW PRI to Adtran Atlas 800
Mar 25th, 2010
Curious if anyones configured T1 PRI back to back
with a Adtran Atlas 800?  Im using
T1 crossover, Layer 1 is active.  Looks like Im fighting aprotocol problem.  I am set to network.
L2 status is TEI Unassigned.
William Bell Thu, 03/25/2010 - 10:44
  • Purple, 4500 points or more
Either the Atlas or the gateway will need to be configured to generate clock for the line.  That is the physical layer, which (based on your post) you have handled.  The next step is to make sure that one of the devices is emulating the network while the other side is a "user" on the network.  The Atlas can emulate the network.  It has been a while so I don't recall the exact procedures.
HTH.
Bill
balitewiczp Fri, 03/26/2010 - 07:57
Thanks for the info.  Would you expect to see Multiple Frame Established?  I've also heard that I might need a standard T1 cable, rather than a Crossover, b/c one side is network.  Thoughts are appreciated.  The GW is configured for network, and clocking is internal.  Still looking at TEI_Unassigned.
Aaron Harrison Fri, 03/26/2010 - 09:19
  • Community Spotlight Award,
    Member's Choice, May 2015
If you are configuring the Cisco GW as the network side, it still needs a crossover (unless the other box does something clever) - the pinout for the port is still a 'user' side pinout, and that's what the crossover fixes.
You have L1 up, so that proves it...
If it is the Cisco that you want as network, your config should be:
Controller t1 x/x/x
Clock source internal
Pri-group timeslots 1-24
! also need to verify/match up your framing/encoding with the other end
Interface serial x/x/x:15
Isdn switch-type
isdn protocol-emulate network
Aaron
Please rate helpful posts..
