is that possible import cs user defined group to RME
Answered Question
Mar 25th, 2010
is that possible import cs user defined group to RME on LMS 3.2  Thanks,
Correct Answer by Joe Clarke about 7 years 3 months ago
No, you can't do an import as each application maintains its own set of user-defined group attributes.
Overall Rating: 5 (1 ratings)
Joe Clarke Thu, 03/25/2010 - 11:33
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
No, this is not possible, but RME can use the user-defined groups in CS.  They should be visible in the RME device selector.
raindrop18 Thu, 03/25/2010 - 11:52
thanks but my objective is since I have problem(takes 5-8 minutes)Cs user defined grups to open one group on topology services.I want to create user defined group under CM or RME on topology services because groups created under CM or RME appears to be very fast on to open topology view.and trying to avoid to creat again close to 200 groups again manually. but appears to be I don't have any other chance.Thanks.
Correct Answer
Joe Clarke Thu, 03/25/2010 - 12:11
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
