NetConfig vs Device Selector/Task Selector
Answered Question
Mar 25th, 2010
I just updated my 3.2 with the latest RME  package: rme4_3_1_win
After doing so, now when trying to run a  "Device Based" NetConfig job I get the "Task Selector" information in  the  "Device Selector" window.
Any ideas?
I attached picture which shows the problem.
Correct Answer by Joe Clarke about 6 years 9 months ago
I haven't seen that before.  This could be due to some bad cached compiled JSP files.  Shutdown Daemon Manager, then delete all files and directories under NMSROOT/MDC/tomcat/work/Standalone/localhost.  Then restart Daemon Manager, and see if that fixes it.
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Fri, 03/26/2010 - 00:29
marius.hole Sun, 03/28/2010 - 03:24
That sorted things out. Everything seems to be working great now. Thank you
